hydrolic lift
R. Baker
06-15-2007 16:51:43
I just purchase a Farmall Super A my problem is the belly mower when raised is very slow to react up or down. It appears to be even slower when tractor is hot. I was wondering if the pump needs to be rebuilt if that is the problem. The fluid level is normal. thanks for any ideas
CNKS
06-15-2007 18:31:26
 Re: hydrolic lift in reply to R. Baker, 06-15-2007 16:51:43
My opinion is that the problem is restriction of flow in the control box/reservoir under the gas tank. You might first try draining the fluid and removing the screen and cleaning it. Refill with HyTran or equivalent. The reservoir can be disassembled and cleaned, a kit put in and it will be as good as new. But, I will not completely rule out the pump, either.
