Order Farmall Cub Parts Online
super cub vs cub
jonnny2006
06-21-2007 19:21:45
how much more if any is the super cub worth than the regular cub? if they were in the same shape? i know a guy who has 2 of them. one is a 8 on a scale of 1-10. the other is a 8.5 How many super cubs did they make in paris? I cant seem to find any info. What did the super cub have the regular cub din't? also what years were the super cubs made?
Hendrik
06-22-2007 03:25:33
 Re: super cub vs cub in reply to jonnny2006, 06-21-2007 19:21:45
Super Cubs were only built in France, but NOT all French built Cubs are Super Cubs. Mike S., a close friend of Bermuda Ken, bought one in Europe and shipped it to his home in Wisconsin a few years ago. He also owns an FV265 (in the model designation the V does not indicate high crop but vineyard).
The seat support of the Super Cub was different and a foot throttle was added. There may be a few more differences which I cannot remember. Serial numbers start with FSSCUB. HTH. Hendrik from The Netherlands
Hugh MacKay
06-22-2007 03:12:32
jonnny: If you go to a site called Les Tracteurs Rouges, you will find all the specs on European built IH tractors. Don't be surprised when you find they were still using letter series sheet metal well into the mid 60s.
The Austrailian built Farmall tractors are very similar to the British built versions, however there were Farmall tractors built in Austrailia using M chassis, operators platform, steering shaft along the top with an M fuel tank and 460-560 front sheet metal. There are a few photos of these in the YT photo gallery.
The French built a C diesel in several configurations including a utility version. I think you'll find this European site interesting.
gene (missouri)
06-21-2007 20:09:17
Are you comparing the numbered series Cubs with the standard Cub?
Locally the prices are almost identical. The numbered series, just a bit higher.
jonnny2006
06-21-2007 21:10:16
 picture of super cub in reply to gene (missouri), 06-21-2007 20:09:17
third party image
pic of super cub
illbuyit
06-21-2007 20:02:52
What the h-== is a super cub?
georgeky
06-21-2007 20:04:46
 Re: super cub vs cub in reply to illbuyit, 06-21-2007 20:02:52
A French built Cub.
