51 H ,THANKS to The Red
Troy pestrak
08-01-2002 07:51:27
I did the fuel and timing adjustments you recommended + put double 2 guage bat cables,plugs,points etc. Runs so good it's scary.
The starter hardly has to turn the engine and its running thanks for the help,Im off to plow the field !
Troy Pestrak
03-28-2006 12:04:14
 Re: 51 H ,THANKS to The Red in reply to Troy pestrak, 08-01-2002 07:51:27
UPDATE
four years later and still runs like a charm. Maintains 10 miles of trails, three fields,three gardens and has cleared two yard sites. Made a set of forks and use it to haul out and pile 12 cords of wood each fall. The only bad part is gas is a $1.00 per litre (4.60 gal)...maybe a good thing or i would never get off! Thanks again.
Ace Schrunk
08-01-2002 08:03:39
If you check the pump when you did the rebulid and oil everything good, start her up it will be ok at least one SM I rebuilt run 30 years never did prime one.
The Red
08-01-2002 07:53:39
Troy that is great news. Have fun out there! Too dang hot in Indy to be outside. :(
