Super A Bright idea
Brian
06-21-2003 20:36:11
Sorry for the play on words, couldn't resist. Well I got my lights all hooked up, and am loving driving after dark ! I do have another question though; when I have it in charge mode I get +10volt (aprox.). When I have all the lights on, I'm getting - 10 volts. I'm sorta suprised that it's not closer to 0 volts, does this mean I'm always draing my battery ? I'm thinking I could really use 1 more light, that would make 4 though, any comments ?
Thanks for all your help !
gene b
06-22-2003 03:51:24
 Re: Super A Bright idea in reply to Brian, 06-21-2003 20:36:11
Dont you mean 10 amps. It should not be -amps when lites are on. Mite need new brushes and commutator cleaned on the armature and also the reg mite need replacing. The 1133 bulbs do draw considerable current as they are rated around 35 watts and using the formula amps x volts=watts you can see total draw is around 18 amps.
Brian
06-22-2003 07:09:21
 Re: Re: Super A Bright idea in reply to gene b, 06-22-2003 03:51:24
My mistake, your right, it is amps.
Brian.
