Super C 3 point lift capacity
Craig
06-22-2003 06:47:50
I have a 1953 Super C and wanted to know how much weight the rear hydraulics should be able to lift.
Bill W.
06-24-2003 09:31:47
 Re: Super C 3 point lift capacity in reply to Craig, 06-22-2003 06:47:50
Craig, I have a 1948 C with a 3-point that operates from the mid-mount rocker arms.
Mine will lift about 650lbs.
Dave_Id
06-22-2003 11:28:48
Need more info. Are you talking Fasthitch?, or a 3 point run off the rocker arms and the touch control, which only will lift a few hundred pounds. A Saginaw 3 point hooked into the hydraulic pump via a manifold will lift the front end off the ground
Craig
06-22-2003 11:53:00
 Re: Re: Super C 3 point lift capacity in reply to Dave_Id, 06-22-2003 11:28:48
I guess it's an aftermarket 3 point hitch off the rocker arms using the touch control. I don't know what a Saginaw 3 point hitch looks like....The original color of the 3 point hitch is yellow (if that helps!).
