Gas problem on 424
Keewaydin
06-29-2003 10:26:27
We're trying to get our 424 back in service after a couple of year's dead storage.It runs but doesn't seem to be getting gas enough to run much above idle. Gas line, filter and outlet from tank seem free and when we take the line off the carb there's a pretty good flow. Carb itself seems clean, cylindrical filter on incoming elbow Ok. This carb has a solenoid on the main metering valve and I've forgotten just what this is supposed to do. Shut the valve when you turn off the ignition to prevent desieling maybe? How should this metering valve be adjusted? Am I correct that the solenoid activates when the ignition switch is on? Thanks kindly for any help you can offer. Keewaydin
Aces
06-29-2003 12:46:28
 Re: Gas problem on 424 in reply to Keewaydin, 06-29-2003 10:26:27
You are right solenoid opens needle when you turn on switch closes to stop desieling when you stop tractor many later tractors you could not adjust if you can adjust yous it will have a screw out end of the solenoid.
dar
07-10-2003 10:46:19
 Re: Re: Gas problem on 424 in reply to Aces, 06-29-2003 12:46:28
According to my I & T manual 4 turns open from closed should be enough to get it to run.
