BN transmission noise
Dave BN
07-04-2003 13:59:03
Have a knocking noise in my transmission. Noise stops when I step on the clutch. Have top and back off of transmission but can't find a problem. Grease was very dirty with a copper or bronze tint to it. I've heard some of you talk about oil slinger bearings causing noise but dont see any bearings on/in the slinger. Would new,clean grease solve this problem or do I need to look farther? Thanks for your responses. Dave.
Shaggy
07-05-2003 07:43:50
 Re: BN transmission noise in reply to Dave BN, 07-04-2003 13:59:03
The oil slinger gear is on the bottom shaft all the way to the back.(PTO end)See if you can stick a screw driver down there and see if it will wiggle around when you push on it. If it wiggles its broke and that could be your noise.Oh you have to take the top off the trans to do this. Somebody else may have some better ideas so good luck.
shaggy again
07-05-2003 14:44:12
 Re: Re: BN transmission noise in reply to Shaggy, 07-05-2003 07:43:50
I may have made a mistake. The oil slinger might be the second to last gear. I am just C.Y.A just in case.
Dave BN
07-06-2003 07:07:43
 Re: Re: Re: BN transmission noise in reply to shaggy again, 07-05-2003 14:44:12
Thanks Shaggy. Oil slinger is the last gear. Don't get much movement out of it though. Will reassemble with new grease and try it. Thanks. Dave.
