HYDRAULIC FILTER- NEED HELP
Paul John
07-05-2003 05:33:38
I have a B-250 diesel Ih tractor that I wanted to modify by putting another inline hydraulic filter into the suction line. (The existing design has the filter under the hydraulic tower) The output of the pump would probably be too much for the filter to go on the output line. Would it work out if I put the filter ahead of the suction screen in the suction line? Thanks in advance.
Michael Soldan
07-05-2003 18:06:49
 Re: HYDRAULIC FILTER- NEED HELP in reply to Paul John, 07-05-2003 05:33:38
Paul, I have a B250 and I would be interested in how you make out. I bought this tractor last spring and I have used it quite a bit. I removed the pan eventually to clean the sludge out of it. I have a pail of gear oil for the rear end and I intend to change it and the hydraulic fluid as well...its just that I haven't found time to do so. They are very handy little tractors. Let me know how this filter system works out..... Mike in Exeter Ontario
Dave_Id
07-05-2003 07:16:37
YOu can buy an inline filter setup at Napa. I bought one for my slip tank.
