Motor Oil Weight for Super A
patpeery
07-12-2003 06:22:15
For Middle Tennessee summers/winters, would running 30w during the warm/hot months and 10w30 during the cold months be an acceptable plan for my little tractor? Opinions appreciated. Thanks
Jimmy King
07-12-2003 12:15:29
 Re: Motor Oil Weight for Super A in reply to patpeery, 07-12-2003 06:22:15
Rotella T is very hard to beat in anything except LP gas I have a friend that trashed a LP with Rotella T the ash is not right.
patpeery
07-12-2003 08:43:39
15w40 it is the next time i change it! thanks guys!
Hugh MacKay
07-12-2003 07:59:36
patperry: I'm in Canada and use 15w-40 in everything from 4 cycle lawn mower, SuperA, 130, 140 and Buick Lesabre. 30 years ago I was running 9 tractors from SA to 1066, 4 GM gas trucks, an Olds and several small engines. I was using 3 separate oils as suggested by oil company. Employees kept getting oils mixed up, so I changed every vehicle to the exact diesel motor oil recomended for 1066, 30 in summer 20 in winter. 15 years ago changed to same grade oil only 15w-40. Of 5 diesels, none of them were ever rebuilt under 10,000 hours. Never had V8 GM that didn't go 300,000 miles. As near as I can tell my SA has never been rebuilt and 130 was 25 years ago. My lawn mower was given to me by the IH dealer the day I paid him for my new 1066 in 1975. It has mowed about 1/4 acre ever since. Deck, wheels, push handle and knife have all been replaced. Engine is intact with a new carb. I forgot one item, 1/2 million miles on a Chevy 6.2 and last I heard it is still going. I have started some of those vehicles at -40, but very rarely. 0 to -20F is the norm in winter. A Farmall 300 was on farm 35 years, always 6 volt and was started unassisted both days it was -40. Am I right, I'll let you be the judge. In my opinion nothing you do to your vehicle is more important than the oil you use.
Ludwig
07-12-2003 06:46:44
How cold does it get there really? A couple days below freezing? Ever below zero?
Probably straight 30wt or even 15w40 would be fine year round. I'd probably do 15w40 as I suspect it gets quite warm in the summertime.
Dave_Id
07-12-2003 06:29:26
Yes, if you use the machine alot, but if you only have to change once a year, I'd consider using 15w-40 all year around. That is what is recommended in my newer Massey Ferguson
