LoBoy charging
JOhn
07-12-2003 08:37:59
'62 Cub LoBoy charges at medium-high to high throttle, but discharges at or below medium throttle. Still a 6V system. Battery just a couple of years old, and cables look pretty good. Is this a regulator, or a generator gone bad? Where do I start?
Bigdog
07-12-2003 10:12:11
 Re: LoBoy charging in reply to JOhn, 07-12-2003 08:37:59
Ground the field terminal of the generator. System should go to full output and the regulator is bypassed. If it doesn't charge then, it's the generator. You might want to re-polarize the generator just to be sure it hasn't lost it's polarity.
JOhn
07-12-2003 10:39:13
 Re: Re: LoBoy charging in reply to Bigdog, 07-12-2003 10:12:11
Bigdog,
Thanks for the advice. Can you give me some advice on identifying the field terminal? How abouyt the repolarization process?
John
