F-12 overdrive stuck???
Jason
07-16-2003 14:54:35
I have a overdrive unit for my f-12, the problem I'm having is it appears to be stuck in one range. It doesn't want to budge when I move the lever. It is off the machine. Does anyone know where I can get more info on this unit. It goes betweent the trans and engine, has casting numbers on it of HT200 (Heisler?????). Any sources of info would be helpful. thanks J
rustyfarmall
07-17-2003 17:00:59
 Re: f-12 overdrive stuck??? in reply to Jason, 07-16-2003 14:54:35
I believe you are correct on the Heisler part, but I have never been into one, so can't help much. I am thinking that maybe these things worked with a planetary type of gear setup, but I don't know for sure.
Doesn't seem to be very many tractor nuts using this forum lately, where did everybody go?
here, try this
07-17-2003 04:52:40
jason, i don't see any replies so will put in my 2 cents. is that an aluminum case? aluminum and iorn and moisture are not a good mix. Is the case bolted together? I would carefully dissasemble the whole thing.
Jason
07-17-2003 09:47:31
 Re: Re: f-12 overdrive stuck??? in reply to here, try this, 07-17-2003 04:52:40
I've taken it apart but still can't figure out how it is supposed to work. I'd like to buy a parts book for it if I can find out where to get one. J
