Missing 350U head+
Slowpoke
08-07-2003 01:14:53
I bought a 350U (SR# 8585) with a missing head and push rods. On the upper rear right side of the block is C-175. All the suppliers want a casting number off the head, but there's no head, so I can't give them a number. Can anyone provide a casting #? Some say that a 300 head will fit, but the bore on the 300 is 3-9/16, 169cu. in., while the bore on the 350 is 3-5/8. No one has mentioned using a Farmall 350 head. Which head and push rods will be a correct replacement? There must be very few 350U tractors around, at least in Northern California.
Thanks for any assistance.
BTW, are the 350U serial numbers continous from '57 thru '58? It looks like they made 1462 in '56 and nearly 13,000 in '57, since the beginning # in '58 is 15049.
dick
08-07-2003 06:48:43
 Re: Missing 350U head+ in reply to Slowpoke, 08-07-2003 01:14:53
According to the parts manual, the head for both the 300U and 350U gas tractors was part number 362533R. The Farmall models used the same engines (C-169 for the 300, C-175 for the 350).
As far as I know, the serial numbers should be continuous.
Hope this helps. Good luck.
Slowpoke
08-12-2003 00:11:26
 Re: Re: Missing 350U head+ in reply to dick, 08-07-2003 06:48:43
Dick... Thanks for the info. Can I assume all 4 engines use the same push rods?
Van
08-07-2003 05:20:24
Either head from a 300 or 350 farmall will fit the 350U. 300 is a C-169 350 is a C-175
