H charging problems
Dan G
08-07-2003 07:50:59
About 6 months ago I re-wired my H and put on a new voltage regulator and ammeter. Things have been working perfectly up until the other day. Now the tractor dosen't seem to want to charge. The ammeter shows a discharge (about 2 amps) unless the tractor is running at full throttle, then the tractor shows a charge of about 2 amps. Does anyone have a checklist of things to do to check for problems? I tried re-polarizing the generator but it didn't help.
Tim Kincaid
08-07-2003 23:44:00
 Re: H charging problems in reply to Dan G, 08-07-2003 07:50:59
Dan, Try some simple things first , clean your commutator bars in your generator first with some fine sandpaper while it is running. Have somebody watch your ammeter while you do it. Also make sure your regulator is still grounded good.
Keep us posted. Tim K.
Bob M
08-07-2003 08:38:54
Dan - Punch below for a quick troubleshooting chart that might help...
Dan G
08-08-2003 09:58:37
 Re: Re: H charging problems in reply to Bob M, 08-07-2003 08:38:54
Thanks for the info. I think I may have a bad generator.
