H height
Spartan Red
08-09-2003 07:19:52
Can anybody tell me what the height is from the ground to the top of the muffler? Thinking of buying an H but first question is, will it fit in the garage?
Any input is much appreciated,
Thanks,
Mike ISW
08-10-2003 06:31:03
 Re: H height in reply to Spartan Red, 08-09-2003 07:19:52
Just went out and measured mine. Approx. 92" to top of muffler. I have to remove muffler to get in and out. Not a big deal for me now but as I get older the ducking at the door will be near impossible. I have a standard 7' door.
Randy in NE
08-11-2003 05:05:43
 Re: Re: H height in reply to Mike ISW, 08-10-2003 06:31:03
My little C just barely fits under with a standard muffler on it. It has less than 1/2" of clearance. You need to be awake just to be sure that you remember to duck at the right time. The H sits a little taller than the C.
rustyfarmall
08-09-2003 14:59:48
It will easily go through an 8 ft. high door, 7ft. will not work.
rustyfarmall
08-09-2003 14:54:46
CNKS
08-09-2003 13:54:30
With standard tires, the H is 74 inches to the top of the steering wheel, so you have to scrunch down pretty good even with the muffler off.
STEVEN H
08-09-2003 08:31:57
No it will not fit in a standard garage with the muffler on. but the muffler is very easy to remove and put back on as it does not need clamps to stay in place. you will need to duck when pulling in and out with the H. it is kind of a pain to have to duck all the time and pull on and off the exauste, but you might just find that you like the sound of the motor with the muffler off, i know i like that sound better. but i cant work with out the muffler onafter a day on her with the muffler on i cant hear realy good. LOL
Gary The Rookie Farmer
08-09-2003 07:56:56
It depends on the tires. If it is too tall you can always cut down the exhaust stack.
