C Engine push rod - anyone have one available
Jerry
08-25-2003 10:23:52
I have one push rod that is bent. Can I replace just one? Would a used one work? I've always marked to put back in the right place as my Dad taught me to at a young age.
Jim in michigan
08-31-2003 19:38:44
 Re: C Engine push rod - anyone have one available in reply to Jerry, 08-25-2003 10:23:52
I may have one,,I have a old C engine in the field I use it for parts,, I will have to make sure,,email me if you need one...Jim
gene b
08-25-2003 19:56:55
Why dont you just straighten it out and use it no body will ever know the difference. The rocker is adjustable enough to compensate.
Jerry
08-26-2003 04:20:46
 Re: Re: C Engine push rod - anyone have one availa in reply to gene b, 08-25-2003 19:56:55
What would be the best method to straighten? I normally would put it in a vice, but not sure if that would work. I did try by hand when I first noticed it, but it seemed quite springy. Should I use heat?
Nick
08-25-2003 12:13:58
Jerry Yes a used one will work. Order does not matter on a engine that has adjustable rocker arms because thats how you make up for wear. I got used ones available if you need one. Email me at cubng70@hotmail.com Thanks LGTMAN Equipment
Gary_N_WV
08-25-2003 11:46:51
Ooops Jerry....you said push rod and I was thinking connecting rod..... .
Sorry.....ignore the information about connecting rods.
Gary
Gary_N_WV
08-25-2003 11:44:27
Jerry, I think....if you look on the rods down near where they bolt around the crank, you will find a number stamped that corresponds to the cylinder number ...1 thru 4.
If someone doesn't respond to you with a spare rod, you can order a reconditioned one for about $40. plus shipping from at least one place that I know of.
If you go to the left of this page and click on classifed adds and place an ad there, I'd say you'd get a response or 2 from salvage yards.
If you repost here and enable your e mail address, you'll probably get e mails with a place or 2 you can get reconditioned rods.
Hope this helps !
Gary
