M MD WD-6 W-6 interchange TD-6
Gary
09-01-2003 04:25:15
Can anyone advise if a gas M or W-6 engine will interchange with a TD-6 4 cyl gas/Diesel engine? Thanks
Haas
09-01-2003 05:24:25
 Re: M MD WD-6 W-6 interchange TD-6 in reply to Gary , 09-01-2003 04:25:15
Don't know specifically about the TD 6. However, the M and the MD chassis are different. It is not a direct bolt in. The side rails are longer on the MD, because the engine is a little longer than the gasoline engine. You would have to make adjustments for that, but otherwise, I think you could do it.
