I.H. TD-18 Dozer
Bruce Kater
09-02-2003 13:13:52
I have a I.H. TD-18 that will not allow me to switch from starting on gas to diesel. The lever binds so it wont change. Any one ever run into this problem before. Externally every thing is ok, so I thought I'd ask before I start to tear it down. Thanks
kal
09-02-2003 19:25:03
 Re: I.H. TD-18 Dozer in reply to Bruce Kater, 09-02-2003 13:13:52
The linkage on the backside of carburetor will also cause this.The lever on the float shut off can go over center and cause it to bind up.
Bruce Kater
09-06-2003 15:02:01
 Re: Re: I.H. TD-18 Dozer in reply to kal, 09-02-2003 19:25:03
Kal thanks for the info but that was already checked & it was o.k. By the way do you own a TD-18?
JerePa
09-02-2003 16:45:54
Take the top cove off. More than likely, the gear mesh is binding or something in the gears. If not, could be one of the starting valves stuck. You didn't say what position it is stuck in. I assumed it is in the diesel mode. You should be able to see the problem whan you get the cover off.
