856 int pto fixed
p miley
09-09-2003 20:39:00
thank you travis and aaces for your help i took the linkage off and backed off the controll valve and the pin was not broken so i started the tractor and held a wrench under the threded cap and pulled on the top of the controll valve and the pto worked what a good feeling i adjusted the linkage and every thing works fine thank you.
Travis
09-10-2003 05:17:06
 Re: 856 int pto fixed in reply to p miley, 09-09-2003 20:39:00
p miley,
I am glad that we were able to help you out, it surprises me how many of these tractors out there are so far out of adjustment. I have a couple of neighbors that know nothing but to just use them and then when something goes wrong I have to go out in the field and fix it. I tell them about it but they just don't realize how important it is. I check the PTO pressure on my tractor every year, just to be safe, I don't want to burn up the clutches just because I didn't take the time to do some preventative maintenance. Anyway, like I said, I'm glad we could help out.
