what can I do????
Jason B.
09-23-2003 14:17:08
On my farmall 460 diesel the pto runs constantly. I would like to know how to fix this if there are any adjustments or what ever else and also cost to fix it. And also does anyone know were I can get a dry element and air canister for it. I would like to get rid of the oil bath unit. Any feedback is greatly appreciated. Thanx.
Mez25
09-23-2003 15:08:41
 Re: what can I do???? in reply to Jason B., 09-23-2003 14:17:08
Does your PTO speed increase with the speed of your RPM's? If it does you are going to have to rebuild the PTO, which depending on where you shop may not be too expensive, just time consuming. Depending on where you are from, I have some ideas for you on some great parts places that have prices you can't beat, lemme know and i'll give you some ideas.
Hugh MacKay
09-23-2003 15:05:36
Jason: The linkage from your pto to engage lever has adjustment, The lever has a notch when disengaged. If you adjust that linkage the lever when in notch should act as brake. If this will not work your pto unit needs rebuilding.
