IH Grain Drill
Andrew
09-26-2003 18:09:25
Does anyone have a Seeding Rate Chart for a IH grain drill. not sure of the model# but it says "Type M.F.D.R.F" on the side of it.
Red/Green
09-26-2003 20:06:52
 Re: IH Grain Drill in reply to Andrew, 09-26-2003 18:09:25
You must have a model M. Is yours a Fluted feed? I have a book for my drill. If yours is a Fluted feed. It has a grain indiator plate on each side of the seed box in the back. At the top it has Millet. (Qts) Next down is Flax.(Qts) Then Wheat-Rye. (Pks) At the bottom Oats-Barley. (Pks)
4 Pecks is 1 bushel.
What do you want to plant? If your planting wheat. The feed cup bottom adjustment should be in the middle. I plant wheat at 8 or just better then 8 pecks per acre.
Andrew
09-27-2003 06:53:02
 Re: Re: IH Grain Drill in reply to Red/Green, 09-26-2003 20:06:52
Not sure if it is fluted feed or not. It has a disc that is kind like a cup that turns and puts the seed out. I have a Seeding Rate chart in the left hand side of the seed hopper but it is so rusted that I can't read it. I was wondering if anyone had a good one that could be copied or something.
Red/Green
09-27-2003 07:17:49
 Re: Re: Re: IH Grain Drill in reply to Andrew, 09-27-2003 06:53:02
From what you are telling me now. I think you have a double run feed type of drill.
I can't help you with that type.
Nebraska Cowman
09-27-2003 04:19:41
here we plant "a bushel and a peck" (5 pecks)
Red/Green
09-27-2003 06:02:08
 Re: Re: Re: IH Grain Drill in reply to Nebraska Cowman, 09-27-2003 04:19:41
In every book i have, and the drill book. 4 pecks is 1 bushel
Nebraska Cowman
09-27-2003 19:04:28
 Re: Re: Re: Re: IH Grain Drill in reply to Red/Green, 09-27-2003 06:02:08
yeah... that's what I said... a bushel (4 pecks) and a peck (1 peck) = 5 pecks. At least where I went to school.
Red/Green
09-27-2003 20:41:38
 Re: Re: Re: Re: Re: IH Grain Drill in reply to Nebraska Cowman, 09-27-2003 19:04:28
OK now i got you.
