Radiator for a Farmall Super A?
SAm in NS
10-02-2003 08:07:04
I have a 53 Super A that is going to get a new radiator. I'm wondering what radiators will fit on it. I know the radiators for the C-123 won't fit but how about the ones for the regular A's? Thanks, SAm in NS
gene b
10-03-2003 03:40:20
 Re: Radiator for a Farmall Super A? in reply to SAm in NS, 10-02-2003 08:07:04
Is the one you have the tall one that came factory water pump and had the taller grille. How high is the gas tank from the rockshaft assy. The ones from a C have different mounts on the bottom. Are your serial numbers matching close to the casting dates.
SAm in NS
10-03-2003 04:07:16
 Re: Re: Radiator for a Farmall Super A? in reply to gene b, 10-03-2003 03:40:20
My current radiator is the shorter one (fitted before the C-123 engines were used) and has no water pump and no thermostat and is a non-pressure system. The gas tank doesn't have the 2 inch gap over the touch control. The tractor serial number is 342732 and the engine serial number is 345567(I think) and the casting codes are all "Y" starting on the 26th of January and ending sometime in March. Thanks, SAm in NS
BIG JOHN
10-02-2003 19:00:35
Your Super A has a C-113 engine as does the A, B, & C. A radiator from any of the three will fit your Super A.
GOOD LUCK
