Aux valves
Foz
10-06-2003 16:08:07
Other than the '06 series of tractors , what other models might I find that the aux hyd valves would swap from to fit my 806?
K.B.
10-06-2003 19:12:54
 Re: Aux valves in reply to Foz, 10-06-2003 16:08:07
Check the part numbers to be sure, but 26, 56, and 66 series should be the same. I'm talking big tractors, 656, 666, 686 seem to be different.
Jim J
10-07-2003 10:36:01
 Re: Re: Aux valves in reply to K.B., 10-06-2003 19:12:54
The 656, 666, & 686 valves are the same as the rest of the 06-66 series tractors. The valves are mounted upside down compared to the bigger tractors
Adam
10-13-2003 05:02:44
 Re: Re: Re: Aux valves in reply to Jim J, 10-07-2003 10:36:01
06-56-66 remotes are the same. I rebuild approx. 40-60 a year. they also can fit 404/504/656/666/686 BUT, many remotes I have seen on these tractors have a larger spool in the valve housing. I shy away from rebuilding these since valves with reduced spool are more common and its easier to find new parts.
