PTO on International 384
Greenacres
10-06-2003 16:48:45
Please HELP!! I have very little mechanical ability. MY PTO will not disengage. Normally it is live and a I can pull the lever and the PTO stops. The PTO is on and I can get it to turn off. It runs fine, however, the lever will not disengage even when I push in the clutch. What could be the problem?
lee balchin
12-07-2003 05:57:33
 Re: PTO on International 384 in reply to Greenacres, 10-06-2003 16:48:45
have mine it jumps out on its own accord
parts man
10-06-2003 19:40:21
If the lever moves but the PTO does not disengage, that is because the pin on the inside of the housing is cut off. Not a big problem, unbolt the 3 bolts that hold the lever casing in the dif housing and wiggle it out, replace the pin through the shaft and put it back together, make sure the knob engages the PTO locking collar. If the lever won't move, it could be jammed in the lever casing or the splines on the PTO shaft could be damaged, either way you'll have to remove the lever to find out.
