656 Leaking around steering wheel
Phil
10-07-2003 18:56:26
Has anyone had a 656 that has leak around the steering wheel? I took the covers off the hood and ran it. No major oil leaks. It just leaks around the rubber boot under the steering wheel. How do you remove the steering wheel? I can get the nut off, but is the steering wheel screwed on or do you need a puller. Any suggestions whould be helpful.
Thanks,
Phil
Phil
10-10-2003 18:51:28
 Re: 656 Leaking around steering wheel in reply to Phil, 10-07-2003 18:56:26
Thanks...Got it fixed with your help!
the tractor vet
10-07-2003 19:39:21
You will need a steering wheel puller , run a 1/4 x28 tap to clean the threads and get two long 1/4x28 i use grade 8 boltsmy bolts are 6 inch but you can get buy with a littel shorter ones . Tighten up the puller and give it a rap with a hammer and the wheel is off , to remove the seal that is leaking remove the snap ring and put the wheel back on just set it on the shaft and give it a quick turn and the old seal will pop out replace the seal and put the wheel back on thighten the nut all done. The last seal pkg. that i put in was under 10 bucks.
