is it an A or is it a super A
H.G.
10-08-2003 08:01:39
I have a farmall tractor and i'm not sure if it is an A or a super A the modle showes me it is an A but the serial # comes up as a super A can someone help please.
modle is FAA and serail # is 256149
thank you.
Al
10-08-2003 17:24:13
 Re: is it an A or is it a super A in reply to H.G., 10-08-2003 08:01:39
Your tractor is a Super A. The FAA prefix was used on the A and the Super. There's a break in the serial numbers, the first Super A serial number being 250001. Touch Control hydraulics first were available for the Super A, but this was an option and though most have it, some were sold without it. I've only ever seen one Super A without hydraulics, and as I recall it was not far from your serial number.
Al
Hugh MacKay
10-08-2003 19:39:33
 Re: Re: is it an A or is it a super A in reply to Al, 10-08-2003 17:24:13
Al: Just a short while back here on this discussion forum we discovered a 1947 Farmall A with factory hydraulics. I don't have the particulars, but at the time we checked out casting codes, tractor and engine serial numbers. It was indeed an A and one of the last built, and did have the factory hydraulics.
Years ago when these tractors were new, my uncle had one with hydraulics. His son tells me it would have been about a 46-47 and was indeed an A. He later traded it for a Super A. One item clear about IH is they were never consistant.
BIG JOHN
10-08-2003 17:16:04
Bud is right the Super A has hydraulics and the plain A does not.
Bud
10-08-2003 10:04:03
I believe it must have touch control ( hydraulics ) to be a SA.
NoahW
10-08-2003 08:38:28
1948 Super A sn#'s start @ 250082. sn#256149 should be a 1948 SA.
