Serail # ??
Mike
10-20-2003 15:31:06
I have a B Farmall with serial # M213374G. What does the "M' & "G" stan for? Thanks
Milton
10-21-2003 12:01:41
 Re: Serail # ?? in reply to Mike, 10-20-2003 15:31:06
Hello Mike, --- 21 / Oct. / 2003 ---
About the only that you could date your "Farmall B" is to get a "Cast Date" (or Chassis Date) off of the Chassis.
It would read something like this 2*25*E (Feb. 25, 1959), but not this reading. It would be on the axle howizing or some where on the Chassis.
The motor may have been replaced so that would be out.
Milton "farmall28@yahoo.com"
Mike
10-20-2003 17:09:09
There is no seat bracket. Looks like after market seat. The #number is off the block where you mention. Could this be a replacement block? Thanks
Red Dave
10-20-2003 17:59:08
 Re: Re: Serail # ?? in reply to Mike, 10-20-2003 17:09:09
It may be a replacement, I don't know what prefix and suffix letters were used on replacement blocks.
Red Dave
10-20-2003 16:18:17
That doesn't look like a serial number, a Farmall B serial number prefix should be "FAB" for both the chassis and engine.
What part of the tractor did this number come from?
The chassis serial number should be stamped on a plate on the inside of the left side seat bracket. The engine serial number should be stamped on a raised boss on the right side of the block just below #1 sparkplug.
Check those places and post back with what you find.
