656 utility help needed
Steve
10-27-2003 21:16:54
Considering buying a 656 utility. The engine seems to run rich, carb has an electric solenoid on the bottom. Can the mixture still be adjusted?
How are these engines on fuel economy?
Thanks in advance- I appreciate the help!!
Diesel Don
10-28-2003 15:25:46
 Re: 656 utility help needed in reply to Steve, 10-27-2003 21:16:54
I have a Farmall 656 and it burns about 2.5 gal/hr doing light work. Mine is a row crop but the the mechanics of the two tractors are pretty much identical.
ny bill o
10-28-2003 02:39:10
the electric solenoid is just a fuel shut off when the ignition switch is off. fuel adjustments will still be made on the carb. my 656s are used mainly for loading and feeding, so don't get used hard. they still use some gas but its livable.
