Thermostat in F-30/W-30
F-Dean
11-01-2003 14:38:11
My F-30 owners manual states: The engine can be operated without a thermostat and valves, but "The passage from the pump to the manifold must be blocked off, . . . or engine will overheat." Has anyone had an overheating problem without a thermostat and without blocking the connection from the pump to the manifold? My W-30 manual does not discuss this issue. Has anyone had overheating problems in a W-30?
Bobcat
11-01-2003 18:06:01
 Re: Thermostat in F-30/W-30 in reply to F-Dean, 11-01-2003 14:38:11
I have a W-30 and a F-30 that have the thermostats removed. I made a block off plate for both and have no overheating problems. It was so easy to make a plate out of aluminum that I never tryed running with it open. Have ran the W-30 on a dyno holding over 30H.P.for well over 20 minutes with no boiling.
