Weight of Super A
Brian
11-05-2003 17:12:06
according to Joe Evans website, the wieght of a super a is 3500lbs, is this correct ??? I thought it was just over 2000.
Brian.
kevin in Michigan
11-06-2003 06:20:13
 Re: Weight of Super A in reply to Brian, 11-05-2003 17:12:06
Ok for me It's a BN. On the scales I get 2650 with me Off the old girl. Do have Front and rear factory weights. Think the rears are 120 each and the front 30. Really don't know. Maybe someone has seen the pics I posted and knows by looking what the weight was for the type I have.
Red Rider
11-05-2003 19:42:49
Brian, My 1954 Farmall 100 with hydratouch with 1 point fast hitch weighs 2800 pounds with no tire fluid or wheel weights.
colekicker
11-05-2003 19:09:34
ok, from running my A over the scales pulling, It has 3 sets of wheel weights, front wheel weights, water in the rear and my 200 lbs on it it weighed in at 3950. So, take away 1000 lbs for the wheel weights and probably another couple hundred for the water and 200 lbs for me and there ya go.
Hugh MacKay
11-05-2003 17:45:39
Brian: My 1953 Farmall Super A weighs 2350 lbs., and that was on government inspected scales. The tractor has no added weight such as wheel weights or chloride. One minor bit of weight probably 100 lbs., the cultivator lift frames were on the tractor.
Noah W
11-05-2003 17:32:46
According to Hot Line Farm Equipment Guide, it weighs 1650 lbs., which is correct. An H weighs 3900lbs., so it would have to be some kind of a SUPER Super A to weigh 3500.
rustyfarmall
11-06-2003 10:30:38
 Re: Re: Weight of Super A in reply to Noah W, 11-05-2003 17:32:46
I have an H which weighed in at 3750 with 200# me on it. Includes belly pump, belt pulley, and pto.
Farmall Ed
11-06-2003 04:48:36
My 42 H weighs 4550 with wheel weights and fluid in the tires. Ed
