B's With final drive noise
Del
11-08-2003 15:01:39
I have 2 B's and both have noise coming from the final drives on both wheels--is this a problem?
Red Dave
11-08-2003 15:26:25
 Re: B's With final drive noise in reply to Del, 11-08-2003 15:01:39
Since I can't hear your noise, it's hard to say, but these old style straight-cut gears do make a little noise normally. If you have serious doubt as to the condition of the final drives, it would pay to take one apart and check it out to be sure. Even if all you get is some peace of mind.
I find that a half can of STP in each side along with the 90 wt gear oil helps somewhat with the gear noise.
Jonathan Mirgon
11-08-2003 21:00:15
 Re: Re: B's With final drive noise in reply to Red Dave, 11-08-2003 15:26:25
I have an (a) and the final drives are noisey to, i believe it is the gears , as I have replaced all the seals and bearings in both sides. And they are still just a s noisey. I have read a lot of posts on this here, and from what everyone else says it is pretty much normal for these tractors, I am pretty sure that the a,b, and bn farmalls all have the same final drives on them.
