Order Farmall Cub Parts Online
Adding a 1 point fast hitch to a 53 Farmall Cub...
Jesse
11-13-2003 09:55:18
How hard is it to retrofit a 53 Farmall Cub with FH? What do you have to change? Can you just buy one and hook it on?
Hugh MacKay
11-14-2003 01:30:43
 Re: Adding a 1 point fast hitch to a 53 Farmall Cu in reply to Jesse, 11-13-2003 09:55:18
Jesse: I have not tried this with a cub, however it should work as tractor design is the same. I did this with a Super A using a hitch from a 130. The only problem I ran into was for the spring assist that helps hydraulics with lifting the hitch. The Super A was drilled in torque tube for mounting one end of spring. The rockshaft however did not have a hole for the other end of spring. I had to change the rockshaft also. I did run it for awhile without the spring, and I'm not sure it helps that much anyway.
Your best bet is to do a very close comparison of your tractor and one built after 1955. I saw this yesterday but held back thinking someone who had actually done a cub would respond, and maybe they will yet. My best guess is if you run into problems, it will not be mounting of main structure but rather a minor item as I did with Super A.
Randy 64 Cub
11-14-2003 04:22:37
 Re: Re: Adding a 1 point fast hitch to a 53 Farmal in reply to Hugh MacKay, 11-14-2003 01:30:43
You will not be able to install the helper spring, but everything else will install just fine. The fast hitch wasn't incoperated to cubs until 1954. Unless you are using a fast-hitch 42A or 59A woods REAR mower you wont have a problem lifting most implements.
Hugh MacKay
11-14-2003 16:25:39
 Re: Re: Re: Adding a 1 point fast hitch to a 53 Fa in reply to Randy 64 Cub, 11-14-2003 04:22:37
Randy: How do you know this? I can think of a dozen implements heavier than a woods mower. I'll also bet it is possible for him to put that spring on his cub. It was possible on my Super A.
Randy 64 cub
11-15-2003 10:21:25
 Re: Re: Re: Re: Adding a 1 point fast hitch to a 5 in reply to Hugh MacKay, 11-14-2003 16:25:39
Prior to 54 there is only one left side hydraulic arm. The one that goes to the spring was not added till 54.
Hugh MacKay
11-15-2003 22:53:57
 Re: Re: Re: Re: Re: Adding a 1 point fast hitch to in reply to Randy 64 cub, 11-15-2003 10:21:25
Randy: That can be changed. If you read just a bit more carefully, that is exactly what I had to change on the Super A.
