B-250Diesel
Per kærsgård
11-17-2003 04:15:34
Help i need some data on my 1957 B-250Diesel.
data on engine and measures and weigth.
Serial number is 14488.
Engine number is 14032.
Per from Denmark.
rastas
11-17-2003 06:28:13
 Re: B-250Diesel in reply to Per kærsgård, 11-17-2003 04:15:34
Per, Re your B250---- Serial no 14488 built in 1957 at Bradford England.
Engine 3 3/8 inches bore. 4 inches stroke.
Valve clearance (hot) 0.020 inches
Injector timing 20% B.T.D.C.
Min. speed 540 - 600 rpm.
Max no load speed 2000 rpm.
Max at full load 1750 - 1800 rpm.
Capacities.
Cooling system 2 1/4 gallons.
Fuel 8 1/2 gallons.
Sump 1 5/16 gallons.
Transmission 4 gallons.
Tread widths front and rear 48 inches - 76 inches
Height to top of steering wheel 59 3/16 inches.
Length 112 inches.
Weight including fuel oil and water, 2996 lbs.
Regards, Rastas.
