Voltage Regulator
KG
11-18-2003 07:40:47
I have a Super A that has a 12 volt system and alternator. It also has a voltage reugulator on it. I thought that a voltage regulator was not needed if there is an alternator. As far as I can see the voltage regulator is not hooked up so is there any reason to keep it?
Doug in OR
11-18-2003 19:50:56
 Re: Voltage Regulator in reply to KG, 11-18-2003 07:40:47
I presume your A was converted to an alternator. If so, they probably left the regulator mounted and disconnected it. If it is not wired, just remove it. Few alternators use external regulators. If my alternator had an external regulator, I'd change the alternator.
old
11-18-2003 07:51:57
That depends on if your alternator has internal or external regulator, if its interanal no you don't need one but if external yes you need one.
You didn't give enough info for me to tell you any more.
Is it delco,motorcraft etc??
kg
11-18-2003 11:08:06
 Re: Re: Voltage Regulator in reply to old, 11-18-2003 07:51:57
I can't tell it is very old and rusty. It had one wire going to it which was not connected when I got it.
rustyfarmall
11-18-2003 12:04:14
 Re: Re: Re: Voltage Regulator in reply to kg, 11-18-2003 11:08:06
Relatively speaking, the one wire alternator with built in regulator is a fairly new version, and has not been available in salvage yards until recently. Most of the 12 volt conversions were done with parts from the salvage yard, to keep expenses down as much as possible. I will just about bet that yours has been done this way, and would require an external voltage regulator.
