Dunham disk.
Dave BN
11-30-2003 03:45:33
Stopped by one of my favorite junk dealers yesterday. One of his new arrivals is a small, tandem disk. It has the name Dunham on each end of the place where you would put cement blocks etc for weight. I never heard of Dunham before. Is this a common name in other parts of the cuntry? A unique feature of this disk is that the end blade or second to the end of each end of each axil has a flange on it that kinda makes it look like a rail road wheel. The flange is 2" or 3" wide and is slightly cone shaped so it is not at a 90 degree angle to the blade. The only thing I can think of is that it is for flotation in very loose or very wet ground. Anyone ever see anything like this? Dave.
Allan
11-30-2003 10:14:25
 Re: Dunham disk. in reply to Dave BN, 11-30-2003 03:45:33
Dave,
I had a Dunham packer one time and it was one of the best implements I ever owned; built to last.
I don't know about the end blades on this particular disk that you are referring to, but in a lot of cases, it is quite customary to have the end blade smaller than the rest of the blades on the gang.
This serves as a "furrow filler"; it makes for a more 'level' till & eliminates that end cut. Maybe this is what they were trying to accomplish?
Later,
Allan
RONALD LASSITER
07-03-2004 12:44:16
 Re: Re: Dunham disk. in reply to Allan, 11-30-2003 10:14:25
I NEED SOME PARTS FOR A 1969 DUNHAM BUSH HOG
Dick
11-30-2003 15:09:20
I think the full name of the company is Dunham Lehr. They also make (made?) front end loaders.
