SMD Head rebuild
49 Cubber!
11-30-2003 04:54:35
These can be rebuilt cant they,new valves or ginding them and the seats right?Also what are the three small valves for?Compression realease?We pulled my buddys yesterday to see the extent of water damamge he has.All 4 cylinders full of water and rust.The upper part of the head looked real good,bottome side was ok,but alot of rust on the head sruface and some on the valves.
paul
11-30-2003 06:55:41
 Re: SMD Head rebuild in reply to 49 Cubber!, 11-30-2003 04:54:35
almost all of the heads i have seen taken off diesels are cracked before you get to excited on overhaul take the head to a good machine shop and have it leak tested some of the cracks are so small you cannot see them also have it checked for warp.good luck paul.
49 Cubber!
11-30-2003 16:01:29
 Re: Re: SMD Head rebuild in reply to paul, 11-30-2003 06:55:41
I plan to do that in the morning,butI want to know if the valves are still avilable and where to get them or are these pretty common.One looks like maybe its pretty much sho from rust,and the 4 little ones look ruff.The rest I think can be saved.
paul
12-01-2003 18:03:19
 Re: Re: Re: SMD Head rebuild in reply to 49 Cubber! , 11-30-2003 16:01:29
check with local ih case dealer if no luck steel wheel ranch or webers tractor works if still no luck i have a few more tricks up my sleeve reply if needed.paul
