M SM Re-Bore kits?
Jason
12-01-2003 18:14:38
Can a Super M re-bore kit (4 1/8 inch) be used in a M block? Or are the blocks different? Thank You!
rustyfarmall
12-01-2003 18:34:40
 Re: M SM Re-Bore kits? in reply to Jason, 12-01-2003 18:14:38
I think you need to bore out the block in the M in order to put in the 4-1/8 sleeves, they will drop right in a super M. The super had the 4 in. pistons as standard, while the M had 3-7/8 standard. So the overbore kit for the M would result in 4in. pistons, while the overbore kit for the super would result in 4-1/8 pistons. The cylinder walls of an M would get very thin if bored out to accomodate the 4-1/8 pistons.
