Order Farmall Cub Parts Online
Cub and 30 questions
Okla/kans Bill
12-04-2003 19:20:28
What are the 2 holes on the righrt side of the hood for inna 48 Cub. Also how far down should I screw the tightning nut on the frot side of the transmission shaft with new cord wrapped around it. I screwed it 2/3s of the way in. Qhoever had it ran over the wrong thing. Theres a chip out of the pulley face, and the pull has a wbble. All 3 shafts leak grease BAD, tho the front is the only one Ive ever replaced. The drawbar was vcompletly broke so it looksa, and the bars holding it have been broke. I know from this youll think its a piece of junk, but to look at it it looks pristene. Oh Also, the Pulley lever will slide out of gear when using it, and the top cap on the pulley leaver has been bronzed. BUT it runs like a champ, as the radiator screen, crank, and all on it. Extension pto shaft with guard. OH Another thing. When Im plowing, itall pull 2 14s fine in a 10 acre field for around 3 rounds, and then it will load up and die. Some times I can push the clutch in and save it, and sometimes not. When it dies, itall crank right back up and go good for awhile and then do it again. And that is right now in 50o weather. Any thoughts
Rudi
12-06-2003 14:53:48
 Re: Cub and 30 questions in reply to Okla/kans Bill, 12-04-2003 19:20:28
third party image
Ralph is correct, the two holes in the hood are used to put oil in the cups for the generator.
Many of your questions can be answered by clicking the link below. Checking the links on the main page will take you to a whole lot of information as these links are devoted almost entirely to Cubs and how to rebuild/restore/repair and maintain said critters. You will find many very knowledgeable people through these links.
Hope this helps a little.
Ralph Thomason
12-04-2003 20:55:14
Bill, I can only answer about the holes in cub hood they are to get to the front and rear genererator bearing with a oil can. E-mail offline I have some answers and questions about the 30 .Thanks Ralph
