460 utility clutch; I need you guys advice!!
Chris C
12-06-2003 21:00:23
While tearing the power steering off the 460 utlity I noticed I have this machine half apart. The question is>> Since I have it this far down..should I attempt to put a new clutch in it even though I don't know that the old one is bad?? Is there some way to tell what the integrity of the clutch is?? Thanks in advance guys.
ken
12-07-2003 06:55:59
 Re: 460 utility clutch; I need you guys advice!! in reply to Chris C, 12-06-2003 21:00:23
do you need to split it to get the power steering off of it.i need to get into mine some day and just wondering whats involved.as for the clutch if your there just as well put in a new one.and when i do get into mine i'm going thru the t/a too.
Chris C
12-07-2003 17:11:18
 Re: Re: 460 utility clutch; I need you guys advice in reply to ken, 12-07-2003 06:55:59
No you don't have to split it to get the sterring box off. It was actually not to bad to get the power steering off..make sure you have some swivels for your sockets.
Chris K
12-07-2003 06:37:31
What model 460 are you re building? Is it a row crop or utility?
Chris C
12-07-2003 17:12:57
 Re: Re: 460 utility clutch; I need you guys advice in reply to Chris K, 12-07-2003 06:37:31
Utility..TA is out too maybe I should just go for it.
Allan
12-07-2003 05:45:08
Chris,
If I've got *anything* torn down to the point that the clutch is right there in front of me, I replace it unless I am absolutely certain of it's condition.
Just makes good sense in my mind. Might as well do it while you are in there.
Allan
