Firing off an M.D
John
12-07-2003 21:28:39
Would appreciate the best way to start up an M.D Farmall 1948. Seems everybody has a diffent oppinon on the subject. A step by step would be a real help. The manual leaves a little room for different interpetation. Thanks for any help. John
Paul in Mich
12-08-2003 07:50:03
 Re: Firing off an M.D in reply to John, 12-07-2003 21:28:39
John, WE had a 48 MD also, and the protocal we used was: (1) Switchover handle foreward, throttle off. (2) Start on gas and let run for approximately one minute, longer if below freezing. (3) After gas warmup, give quarter to half throttle. (4) Pull switchover handle back. (Note: No more than one second should elapse from throttling sequence and switching from gas to diesel) There may be a more proper way, but this always worked for us. While on the subject, we always idled down on diesel, then switched back to gas with throttle off and let idle for approximately 15 seconds then pulled back switchover handle with throttle completely off to shut off tractor. This was to create a cool down period before shuting down completely. I know some people just cooled down on diesel, and didn't switch to gas before shutting down. I really don't know which is correct, or if there is a correct way other than making sure the tractor isnt shut off immediately without a cooldown. This prevents cracking the head.
Jim E.
12-08-2003 14:54:08
 Re: Re: Firing off an M.D in reply to Paul in Mich, 12-08-2003 07:50:03
The reason for switching back to diesel is to be sure that decompression valves are closed, to help prevent warping of the valves.
