SM blowing oil out #2 exhaust manifold
Jonesy
12-08-2003 17:04:22
Have a SM that makes according to the gauge 75# oil P when running. It blows oil out around the manifold gasket on #2 exhaust port. The tractor didnt smoke @ all until we ran it for some time. Now it smokes intermitently. Pulled off manifold and found oil all in the #2 exhaust valve. Im 99% sure that the rings in the cylinder are good but havent done a wet/dry comp check yet. I degreased the area and held the starter in for a while and built up around 40 #'s oil P. Oil was leaking down the valve stem from the head. Im leaning towards a bad valve guide but I could use a second opinion . Ive never seen a guide leak that much oil past if thats the case.
grizzly
12-09-2003 19:02:45
 Re: SM blowing oil out #2 exhaust manifold in reply to Jonesy, 12-08-2003 17:04:22
had a to20 and the valve seat come loose and it poured oil out the exhaust
Greasy John (Or)
12-08-2003 20:43:51
Well Jonesy I'd pull the plug out of that cylinder if it look the same as the others then sure nuff its a cracked or scored guide/valve stem. If it was rings it would foul the plug and smoke . John Good luck.
