Torque Values F-14
Terry R
12-13-2003 05:07:27
I am reassembling my F-14 engine with new rings and bearings and cannot find the torque values. I am especially looking for the Main & Rod bearing caps along with the head studs. Does anyone know where I can find that info? I have 3 different repair manuals that don't mention torque values at all.
Zak
12-13-2003 06:37:06
 Re: Torque Values F-14 in reply to Terry R, 12-13-2003 05:07:27
I just went through the same problem when rebuilding my F-12. use the following torques and you'll do fine.
Rods- 45 ft/lbs
Mains- 95 ft/lbs in three increments. Try 50#, then 75#, then final torgue to 95#. Don't use oil on the studs and DON"T back off once they are torqued. If you think you went a little over, leave it.
Head- I went to 75# the first time and it leaked. Used 95 (same as the mains) and it was fine. A word of advice here- do yourself a favor and put a thin bead of copper permatex around every water passage hole in the head gasket, on both sides of the gasket. You'll be far less likely to have leaks. I learned this the hard way.
