Do new sleeves need honing?
Brad
12-17-2003 09:00:32
This may be a simple question, but; I just got new sleeves and pistons for my 46 A. The sleeves have the cross-hatch honing marks. Is this sufficient or do I need to do another hone?
Jonathan Mirgon
12-17-2003 19:59:32
 Re: Do new sleeves need honing? in reply to Brad, 12-17-2003 09:00:32
The new sleeves and pistons are machine matched to each other , by far more supperior techniques than a 20.00 cylinder hone than runs on the end of your drill, Dont hone the new sleeves ! They are already to go, just clean them up good with soap and water, and then throughly dry them.
E J
12-17-2003 11:43:25
Take the new sleeves and wash them in detergent soap befor you install them.
aaron
12-17-2003 09:58:58
Do not even think of honing new sleeves!
Then you will not have 'new' sleeves anymore.
They are perfect, just be sure to oil up the piston real heavy when you tighten with the ring compressor and install.
I bought a rebuild kit; new sleeves, rings, wrist pins, and pistons for my Farmall M. Installed from the box and the M had incredible compression.
-Aaron
One Row
12-19-2003 10:32:52
 Re: Re: Do new sleeves need honing? in reply to aaron, 12-17-2003 09:58:58
AAron, Where did you purchase your rebuild kit?? I need a good quality rebuild kit for a Super C, who do you recommend?
Thanks,
One Row
