hydraulic cylinder on 27V sickle bar mower
Jon
12-21-2003 16:17:00
I have a Ih model 27V mower and want to put a hydraulic cylinder on it. Can someone email pics of how they got there hydraulic cylinder on their mower (brackets,set up,etc)? Any help greatly appreciated.Thanks
randy hall
12-21-2003 20:59:17
 Re: hydraulic cylinder on 27V sickle bar mower in reply to Jon, 12-21-2003 16:17:00
the factory setup uses a long rod back to the mower lift pivot shaft up to the tractor with a lift all cylinder hooked to the drawbar clamp, this piece may have to be turned so the long end with the hole in it points down to hook the back of the cylinder to, then there is another piece that bolts to the boss on the side of the transmission that the long rod and the front of the cylinder pivots off of.this is the setup for putting your mower on a h or an m. it would be easier to buy a manual for your mower on ebay if you have never seen this before or you could rig up some brackets to use a standard 3" by 8" cylinder.
Heat Houser
12-21-2003 17:44:32
I am looking for the manual lift lever for a 27V that is used when mounted on a B Farmall.
Do you have a lever that you are going to remove? Do you know if it is for a B?
