International 5088 leak
Chad
12-23-2003 19:29:29
My friend has a 5088 and we were discussing a leak on the tractor. My question is his right side rear axle seal is leaking, is that just a cap with the seal behind it? Can you do it by just removing the rear cast and tire and slide that cap off? The leak is getting worst-hytran ain't cheap either.
Thanks guys.
bermuda ken
12-24-2003 05:49:03
 Re: International 5088 leak in reply to Chad, 12-23-2003 19:29:29
Remove the wheel and pull the drain plug on the bottom of the RH axle housing. Take off cap and replace with the new, improved seal. If you don't drain the housing, you will get a nice oil leak.
Follow the instructions on the seal kit too for proper install of the wear sleeve. Also retorque the wedge lock wheels and the RE-CHECK their torque.
scotc
12-26-2003 10:15:38
 Re: Re: International 5088 leak in reply to bermuda ken, 12-24-2003 05:49:03
good idea on those wheel wedges is to keep a ratchet for them in the tractor and check them a few times a day, accidentily slid a wheel out about 4 inches on our 1066 when we put new (luckily long) axles in it
Chad
12-24-2003 10:49:28
Thanks for the answer, I think I am going to try to talk him into bringing that into the shop to get done-don't think we can handle that cast hub and a 20.8 filled with fluid. Seems like a bad situation to me.
Thanks again.
honesthill
12-25-2003 03:41:00
 Re: Re: Re: International 5088 leak in reply to Chad, 12-24-2003 10:49:28
Chad, use a forklift. I have done a few. Just make sure that the tractor is blocked WELL.
Chad
12-25-2003 19:20:56
 Re: Re: Re: Re: International 5088 leak in reply to honesthill, 12-25-2003 03:41:00
Thanks for the advice on the forklift idea. We thought about using the neighbors Bobcat with the forks but my friend wasn't to thrilled about that. He decided to bring it in in March. Winter here in Wisconsin-don't need it right now.
Hey let him spend his money, it isn't my tractor. He is talking about replacing all the hy-tran too 45 gals?-easy $1000 out the door. Wish I had money like him....
Thanks again.
