Square Head Bolts - Where to Get?
Dave G
01-02-2004 08:00:52
Can anyone tell me where I can get 5/8 inch Square Head bolts? Need them for my Farmall B wheels.
Thanks
Richard C
01-02-2004 21:08:33
 Re: Square Head Bolts - Where to Get? in reply to Dave G, 01-02-2004 08:00:52
I too looked at my local case dealer. Didn't have em. But the John deere dealer next door had then in stock. go figger huh.
big fred
01-02-2004 17:05:04
I used hex head bolts on my B, worked fine, but of course not original. Just jam a flat blade screwdriver in next to the hex head when you torque them down to take up the little bit of extra space.
Rodger Wells
01-02-2004 10:02:21
You can buy them through IH, but be sure you get Cat-5 (hardened) bolts. How many do you need? I think I have some in the barn.
Dave G
01-02-2004 13:12:00
 Re: Re: Square Head Bolts - Where to Get? in reply to Rodger Wells, 01-02-2004 10:02:21
Thanks for the IH dealer reminder. I did call them up and ordered some. Sometimes it's not worth looking around the IH dealer.
Paul in Mich
01-02-2004 14:39:26
 Re: Re: Re: Square Head Bolts - Where to Get? in reply to Dave G, 01-02-2004 13:12:00
Not only does most IH dealers carry them, but they are cheaper than most any other place you might try. I bought some from a wholesale fastener distributor, and the next time I was at the IH dealer, inquired, and found out that they had the same thing at a lesser cost. From now on I default to IH and go from there.
CNKS
01-02-2004 19:11:33
 Re: Re: Re: Re: Square Head Bolts - Where to Get? in reply to Paul in Mich, 01-02-2004 14:39:26
I needed the square head bolts to hold the rims on my Super H, Case/IH wanted $11 each for them. Got them from Pilot Knob Restorations, for $3.25 each. These were dot head reproductions (they were 1/4 inch over the OEM length). If you don't have to have the dot head, they are probably cheaper somewhere else.
Paul in Mich.
01-02-2004 19:41:25
 Re: Re: Re: Re: Re: Square Head Bolts - Where to G in reply to CNKS, 01-02-2004 19:11:33
Ah yes, finding the dot heads can be a challenge. Purists like ourselves tend to stick up our noses at anything else.
Dave_Id
01-02-2004 11:13:30
McMaster/Carr ..... do an internet search. They have everything.
Super Dave
01-02-2004 09:47:42
Your local John Deere dealer stocks them in 5/8 x 3" square head to mount wheel weights. I would think that Case IH dealers would have them too.
Robert
01-02-2004 09:38:44
Personally, I have not tried this place, but they may be worth a try:
Link
That is not their home page, it is:
http://www.masterbolt.com/index.html
CRUSADER
01-02-2004 08:44:26
Happy Hunting!
Simular problem on a Farmall B that my father bought. He told me that no one had the square head bolts anymore. I found some, but it wasn't an easy task. Suggest you check out some of the Hardware Stores, Welding Shops, Equipment Yards that have been around awhile. I found the ones that I needed to use at a Welding Shop. The owner of the shop said he "didn't think he had any that size, but I could look if I wanted to." Even he was surprised when I found enough of them.
Jim
FASTENAL
01-02-2004 08:28:29
N/T
