560 HP w/ high domes?
Farmall Daddy
01-02-2004 12:16:43
What kind of horsepower can I expect with 3 9/16 high dome pistons? Everything is stock on the tractor right now, and I am ready to overhaul the motor. Thanks for any ideas!
justin
01-02-2004 12:56:46
 Re: 560 HP w/ high domes? in reply to Farmall Daddy, 01-02-2004 12:16:43
why not go with a set of 3 3/4" overbores?? These piston & sleeve sets will put you up to about 73HP, but the block will have to be bored to accept the sleeve. IH and M&W made this conversion kit for the 560 gas, and I have the IH kits available. email for more info
Farmall Daddy
01-02-2004 18:17:47
 Re: Re: 560 HP w/ high domes? in reply to justin, 01-02-2004 12:56:46
I don't want to get into the boring it out. Kinda exspensive for my wallet.
justin
01-02-2004 18:20:41
 Re: Re: Re: 560 HP w/ high domes? in reply to Farmall Daddy, 01-02-2004 18:17:47
it is actually not that bad.. My local napa does it for $8/hole..
Farmall Daddy
01-03-2004 12:03:55
 Re: Re: Re: Re: 560 HP w/ high domes? in reply to justin, 01-02-2004 18:20:41
Did you mean $80 a hole? Let me know on that. Thanks!!
Farmall Daddy
01-03-2004 12:02:58
I have priced boring the block out to a 301 ci, and it will rack me around $700. I don't have that kind of money, so i am going to stick w/ the high domes. It did good in the 10000 pound class with only 50 horsepower, so i don't think that I need that much. If I were to bore another 560 out, would I have to change the radiator to accommindate the heat situation. I have heard that you have to put in an 806 radiator to keep it cool. I plan to use this tractor in the field as well. Thanks for any help.
justin
01-03-2004 12:35:23
 Re: Re: Re: Re: Re: 560 HP w/ high domes? in reply to Farmall Daddy, 01-03-2004 12:02:58
WOW!!! That must be one high priced machine shop.. I have rebuilt several engines where the cylinders had to be bored, and every time it was $8/hole. Heck, I have had machine shops install repair sleeves in several engines where the cylinder was distorted, and that only cost $125 (repair sleeve included at $75).. I guess I am lucky to have this particular NAPA machine shop in my area..
Farmall Daddy
01-06-2004 14:31:49
 Re: Re: Re: Re: Re: Re: 560 HP w/ high domes? in reply to justin, 01-03-2004 12:35:23
I wish that somebody like that was in our area, lol!!
