hot coil
Jim
01-08-2004 20:07:08
Thanks to all you guys, I now know a lot more about the electrical system on my 300. So heres my question..Its been converted to 12v, there is no ballast resistor. The coil is not too hot to touch, but you wouldnt want to leave your hand there for more than a few seconds. I dont know if its a 6 or 12v coil.
Tractor starts great, runs fine. Have not had a problem with burning up points.Only problem ive had is corrosion on the distributor end of the plug wires. Should I be concerned about the hot coil, or leave well enough alone?
secondly, Im going to install an original style ammeter. Do i need to do anything to it now that the tractor is 12 volt?
Bob
01-08-2004 22:23:14
 Re: hot coil in reply to Jim, 01-08-2004 20:07:08
The coil sounds abnormally hot to me, but it's your call. Add a ballast resistor now for $10 - $15, or keep running it and see when and if the points or the coil fail, and then add a ballast resistor or a true 12 Volt coil, and replace the points.
As a side note to the hot coil, several years ago someone brought an old Chevy truck over to our shop. They had converted it to 12 Volts without a ballast resistor or a 12 Volt coil. A few minutes after they had dropped the truck off, we heard a BANG outside the shop, almost like a shotgun blast. We could not figure out what the noise was until a day or two later when we went to start the truck to drive it into the shop, and it would not start. Upon further examination, the top of the coil was blown out of the metal can, and there was oil splattered all over. Apparently, when they dropped off the truck, they stalled it and left the key on. They coil overheated, and boiled the oil inside, blowing the top off. I have seen this one other time, on an IH truck with the 404 motor. Apparently, the key was left on, and the electronic ignition box shorted out, causing high current flow through the coil, until it also blew it's lid!
The ammeter does not care if the system is 6 Volt or 12 Volt, but a determining factor in choosing an ammeter would be your charging system... Do you have a 60 or 70 amp 12 Volt alternator, or a 30 amp 12 Volt generator? You need to select an ammeter with the full scale reading compatible with the charging amps. Of course, the ammeter will seldom read the full charging rate unless the battery is unusually drained upon startup.
Jim
01-09-2004 07:15:13
 Re: Re: hot coil in reply to Bob, 01-08-2004 22:23:14
Went to the auto parts store this morning..a 12v coil that cross references to the Wells LU800 cost me 10 bucks...so cant see any reason to go to the ballast resistor when I can have a new coil for 10 bucks.
Thanks for all your help, Bob.
