H governor
Jeff
01-12-2004 16:54:33
I have an H that hasn't run in 15 years or so that i am trying to get going. When i took the carb off, the carb to governor linkage would not move at all. i took the linkage apart and found that it was bent right about at the place where it comes out of that tube on the end that connects to the linkage that goes down to the governor. i am pretty sure that bend was causing it to bind up. i assume its not supposed to be bent so where could i get another one or can mine be straightened? I am wondering how it would have got bent in the first place. it appears that someone has already messed with it sometime in the last 60 years. would they have bent that part to compensate for wear somewhere or to stop surging? thanks for the help!
Jeff
Jim in michigan
01-13-2004 06:53:35
 Re: H governor in reply to Jeff, 01-12-2004 16:54:33
I think i have a spare,,email me and I will check and see,,,Jim
wiliamf
01-13-2004 03:39:33
If it's the part I think you mean, the shaft that runs through the tube from the gov. to the carb, yeah it's 'spose to be straight. Should be available from Case IH, or one of the online parts and salvage places.
Wm
