300U Steering just gave way?
Dennis
01-24-2004 19:28:33
I was about to do some raking with my 300U. I started to turn the steering wheel while I backed up and all of a sudden i felt the wheel give and now the wheels dont turn. I can turn the wheel but the wheels dont move. What have I done? Is there a woodruff key in the steering gear box or something that broke?
Please help. Thanks in advance.
TDK
01-24-2004 20:11:09
 Re: 300U Steering just gave way? in reply to Dennis, 01-24-2004 19:28:33
There's a stud on the shaft that turns left side wheel. This stud runs in the worm gear on steering wheel shaft. The stud may have worn/broken off or teeth on left and/or right shafts have broken off. The teeth are a weak spot on these str. boxes & parts hard to find and expensive.When you tear it down let us know how it looks.Good Luck!
Dennis
01-25-2004 05:10:05
 Re: Re: 300U Steering just gave way? in reply to TDK, 01-24-2004 20:11:09
Thanks TDK. I have been staring at the parts catalogue looking for that stud you mentioned. If you have a parts catalogue, can you tell me which part you are talking about?
I have a horrible trans fluid leak coming from under the steering box so I can fix that too, but I just am trying to figure part of this out before I take it all apart. Thanks for your help. I appreciate it.
TDK
01-25-2004 14:48:11
 Re: Re: Re: 300U Steering just gave way? in reply to Dennis, 01-25-2004 05:10:05
Parts man. TC-57A W/O power steering:pg.#247; illustration#45;part#365841R91 With power steering:pg.#252;illustration#43;part#365841R91. The stud can be seen on the"flange" end of shaft with teeth,opposite of teeth.This stud runs in #17(pg.#247)& #31(pg.#252).Let me know if I can help!
