C water pump
Chuck G
01-28-2004 06:18:44
How much trouble is it to put a water pump on a C that does not have one. Also is it something that will improves the tractor cooling and how does it affect the resale.
Al
01-28-2004 07:27:43
 Re: C water pump in reply to Chuck G, 01-28-2004 06:18:44
Remove bottom water inlet going into block. Bolt new pump up, add longer fan belt. You will no longer be able to use the temp. gauge if there was one.
Some say that it circulates the water better. You probably won't hear it "gurgle" when you shut off. If you are working it really hard it might help some but if everything is in good working order it's really not necessary in my opinion.
Al
Randy in NE
01-28-2004 10:47:36
 Re: Re: C water pump in reply to Al, 01-28-2004 07:27:43
I would agree with Al. These tractors were designed to operate without a water pump. As long as the water jacket/ports are clean and the radiator in good shape you should not have any problems. The only time my C over heated was when I let it get low on water on a 95 degree day.
